FOR SALE Icon pistons & comp pro magnum rockers
jld440
10:52 PM
tyler.tx
Feedback: 5 / 0 / 0
Platinum Series Pistons - 4.375 -4 FT
Used pistons are a 4.375" bore Flat Top piston which will work in either a 440 block with our 4.25" stroke and 7.100" rod "512CI" stroker combination, or in a 400 block with our 3.915" stroke and 6.535" rod "470CI" stroker combination. The compression ratios and distance below deck will change slightly depending on which stroker combination you are using these pistons with. Click on the part to see our table with detailed compression ratios. All our platinum pistons use 1/16, 1/16, 3/16 ring pack for less frictional loss, and weight saving, full floating .990 pin size.$500.00 plus shipping
Comp pro magnum stainless 1.5 roller rockers $400.00 plus shipping
