Interior interchangeability
plymouthman72
7:42 PM
Dallas-Fort Worth
I have a guy interested in my extra set of 73 roadrunner seats for his 70 GTX. I am pretty sure the front buckets are the same frames but wanted to check on the back seats too. Are all the seats interchangeable between 70 and the other years, just different covers and pads?
Thanks for the help.
Rears are totally different, won't even latch in.
Fronts are similar and will work, but some parts are different. like the backs, latches and the top part of the seat back.
These statements are Charger based, but maybe similar to Plymouths.
Fronts are not same frames exactly, just similar look. However will work as full asembly, using the correct 70 tracks. Can't tell if 71/74 tracks will be a direct fit on floor panel.
For new 70 covers, will need to consider foam is diff so, is hard to fit 70 covers on a 72/74 foam ( and frame ) setup.
Actually the back frame changed in mid 71 year. This made diff the seat back panel and latching from second half 71, but keeping the same foam than 70.
Rear bench is as stated, a very diff monster
