Interior seat questions
Wizard
5:45 PM
Dillsburg, PA
I have a 63 ply Belvedere 2 door post car. I also have a 65 Ply Belvedere II 4 door which has a bench and rear seats. Are the bench seats and rear seats the correct seats/same for the 63 ply Belvedere? I need the interior for the 63.
Also, I have a 64 Fury convertible and a 64 sport fury convertible and 64 hardtop. Would any of the 65 belvedere interior work for any of these cars be correct? The bench seat and rear seats?
Basically, what can I rob from the 65 Ply Belvedere II that will swap in stock and be correct for any of the 3 cars I have?
Good memory test for a New Year's Day. If I recall correctly:
Front bench you're likely aware won't work because of the split back requirement for a 2 dr. The 4 dr bench would bolt in just fine, but access to back seat would be difficult at best.
Convertible rear seats are unique. No luck trying to use a 4 dr rear seat in any of those.
2 dr and 4 dr rear seats will fit either body style, but there is a difference in the front outer corners of a 4 dr bottom cushion. They tuck in quicker than a 2 dr rear bottom cushion, to make foot access through the rear doors easier. I've switched them around myself over the years and the average person wouldn't know the difference. I've even seen a few 2 drs that I thought were pretty original, with a rear bottom cushion that looked like a 4 dr cushion to me. I stripped 65 Satellite 2 dr HT last summer and the rear bottom cushion on that car was noticeably different. I sold it to a guy doing a 4 dr conversion on a 64. A few years back I did a 64 Dodge 4 dr to 2 dr conversion and used the original rear bottom cushion. Lots of people have seen the car and not one has commented on the rear seat.
Hope this helps.
