Iron Head welding repair
Rustyiron
6:36 AM
Texas
I am needing a head repaired and looking for recommendations. Who’s had one repaired?
It all depends on what type of repair it is. Where is it located? Some repairs are not feasable.
Some are easy-peasy. Pictures? More info.
15 years ago I torched a slot between 2 cylinders on a set of 906's that were ported, had bronze guides and big valves. I took it to a guy that specialized in repairing cast iron. It had to wait 3 days because the kiln that he used for heating was slowly cooling a caterpillar block he had repaired. It cost $120 for the welding. Heating it for welding ruined the guides. I forget what that cost. Of course the seats had to be reground, but I do that myself.
These days I would probably go with new aluminum heads.
bry
Saw in a magazine a hemi head with a valve punch into chamber, didn't hit one v seat slight damage to other. They heated head to 1300* covered the undamaged chambers with fiber=fax. then gas welded hole shut. Think they rehated it then pulled it out to cool. Then machined the chamber.
Unless you have a very worked or special head it's probably not worth the cost. Especially if it's a crack.
What's the issue with it?
Doug
