63fury500
- 10:15 AM
- Jun 19, 2016
- Beaver Dam, Wisconsin 53916
For sale 1 jesel kbd 35000 belt drive new in box,part of engine build thats not going to happen,save big,paid over 1300 for this,sacrafice for 1175.00 free shipping usa email benfrank@charter.net
fits all Big Block Mopar. All hardware, tools and billet aluminum driver included.
* 2024-T6 billet aluminum Spider
* Heat-treated steel crank pulley
* PTFE coated high-vacuum cam and crank seals
* Grade 8 hardware
* Patented HTD reinforced belt
* Easy, accurate external cam timing adjustment
Chrysler BB 383/440/HEMI Big Block
Belt Drive System Style: Dry
Adjustable Cam Sprocket: Yes
Camshaft Location: Standard
Belt Included: Yes
Belt Drive Housing Material: Aluminum
Belt Drive Housing Finish: Natural
Quantity: Sold as a kit.
Break the chain with built-to-last, built-to-win camshaft belt drives from Jesel. For engine builders and racers currently running chain or gear drives Jesel offers cost effective alternatives--solid upper pulley design systems. Made in the USA, these camshaft belt drives feature a solid, one piece hard-coated billet upper pulley design that offers cam timing adjustability of ± 8 degrees. Proven standard features such as a 25 mm reinforced HTD belt, bronze thrust washers and high vacuum Teflon-coated cam and crank seals will reward you with years of dependable service. Camshaft belt drives reduce oil windage, they are significantly stronger than timing chains and are gentler than gear drives on the valvetrain.
* Grade 8 hardware
Belt Included: Yes
