manic_mopar
Hey Guys, I'm more of a lurker than an active poster, but thought i'd share this with yall. I was having engine problems with my 440 stroker build. The motor would cut out after running for a little while, progressively getting worse with each time it was driven. After talking with Don from FBO systems (he did our recurved distributor, fuel pump, and carb), he suggested it was my chrome box ignition overheating and then cutting spark to the system.
I decided to go ahead and do an upgrade, and got his ignition box w/ rev limiter and the new coil. This also required to bypass the ballast resistor with a jumper, but I couldn't quite get the jumper to work on the ballast, nor did I like the look. I saw someone post on here to gut the ballast resistor and wire it within for a stock look. This is easier to do than I was expecting! I also went ahead and ordered the Year One engine harness to start my slow progression towards total wire replacement/upgrade.
The car ran fantastic after the ignition system upgrade! Just now finishing up the wiring harness. The one from Y1 is almost exact to the one I yanked out of the car. I love having the correct wire colors to correlate to the wiring diagrams.
Now on to upgrade all the other harnesses and connectors through the car! my year end goal is to have it all rewired.
