K Frames
66/500
9:00 PM
new jersey
Does any body know if a big block K Frame from a 65 Belvedere can be used on a 66 coronet big block ?
NOPE The engine is forward on a 65. Use a 66-70.
You can use it but the fan will be in the radiator and you’ll need to fabricate a trans mount and a longer driveshaft, new exhaust pipes.
Folks use a 66-70 Kframe on the older B-bodies to move the engine back towards the firewall. I seem to recall it is 2” difference.
I have one from a 66 if you’re interested
Hey guys thanks for the information. I seen an ad posted on Craigslist that had a 65 b body K Frame posted complete with control arms and a disc brake set up. i thought it would be a good way to do a disc brake conversion.
Thanks again!
