lcd dash / gauge bulbs
boneheadsGeTeX
1:00 PM
clover sc
iv started working on my gauges, I got new boad for tack (MSD), over lays for faces, and soid State limiter,,, also plan on new bulbs, seen where they have LCD bulbs, has anyone used them,? wonder if there briter? Also the lcd bulbs come in blue, if I use blue can I do away with the blue caps covers on the inside of gauges?
Yes, you should be able eliminate the blue cap, since the bulb will glow blue. Did you make your own volt regulator? I found an old article in Mopar Action that showed how to open the can, remove the mechanical unit and install a solid state piece. very stealth. regards Chris
No I havent done the voltage regular , iv got under dash harness , engine harness , and working on gauges , iv got the soid state limiter on the back of the gauges,,and tack board of MSD,,,,,,, Im not good at electronic s at all , need all the help I can get,, do I need voltage regular? Any other thing I need? I only want to do this one time and do it right,,
I heard of people switching over to LED bulbs, but not LCD.
