These are made of unobobtanium. FMJ isolator pads are to small as well as the metal bracket to use with them. You could make them work.
I moved away from them and used a engine bracket to cut up and down to make a washer as thick as the perch is and a hole to mate with the earlier leaf springs deleting the iso suspension in full. The car now rides like the older suspension which is a slight disappointment but does react better and quicker.
i talkedto espo , they said the aspen ones were the same , my measurment was 6.75 theirs 6.25 , i wonder if the pick ups or some other had the same if they had them at all , Thanks for the reply
