SOLD LEED Brakes Master Cylinder and Brake Booster Combos FC2003HK
69ChargerR/TSE
12:09 PM
Fort Worth
Feedback: +2 / =0 / -0
Summit Racing Leed Brakes FC2003HK LEED Brakes Master Cylinder and Brake Booster Combos | Summit Racing
For sale, doesn’t have the lines in the photo.
$300 or best offer.
Buyer pays shipping.
Upgrade your factory manual drum brake car with this 8 in. Dual Diaphragm Power Brake booster & master cylinder kit.
This kit is designed to work with factory 4 Wheel Drum brakes using a 1" bore dual bowl master cylinder.
In this kit we include an 8" power brake booster, mounting brackets, adjustable proportioning valve and a 1 in. bore disc brake master cylinder.
A great kit with easy installation. The adjustable proportioning valve included in this kit allows you to fine tune the amount of pressure your rear brakes receive in order to prevent rear wheel lockup.
Leed Brakes power booster assemblies are shipped fully assembled.
This insures proper adjustment of the pushrod between the power booster and master cylinder and proper fitment all valves, lines and brackets for a trouble-free installation.
No I haven't. I have a 68 Fury
This fits your: 1968 PLYMOUTH FURY
Special Attention:
Please be aware, this kit is designed to convert factory manual drum brake vehicles to power disc brakes. If your vehicle came with factory power brakes, you will need to either swap out the power brake firewall plate for a manual version, or modify the factory power brake plate to accommodate this system.​
