Lengthy list of parts needs.
pinkpanthr
8:48 PM
Nicholasville, KY
Feedback: +0 / =0 / -0
A good set of 906 440 heads that don't need much more than freshened up.
A good oil pan for a 68 roadrunner 383
Any gear ratio sure trac 8 3/4 rear end for a 68 RR
Good set of leaf springs
radiator
magnum 500 wheels 15 in. 4 by 41/2 bolt pattern
any and all weatherstripping for 68 RR post car.
68 plymouth side markers
68 roadrunner taillights
battery that will hold a charge
driver quality outer door handles
window cranks
may be interested in more for a 68 RR what do you have?
I also have quite a few things that I could possibly trade.
Full set of 14 in steelies with roller only tires from 68 rr
4 original full wheel hubcaps
Original distributor ( needs points)
Original Carter AVS (needs complete rebuild)
Original 11 x 21/2 front drum brakes, spindles etc. drums will need turned but have never been turned. spindles backing plates etc. will need cleaned up.
original black steering wheel from decor package with center pad and horn ring 68 RR.
Original black seatbelts ok for a driver would need some work otherwise. (faded,dirty, etc.)
new brake shoes for 11 x 2 and a half drums.
inner door handles chrome is a little pitted.
LF lower fender patch panel from year one.
some others just ask.
PM me with wants and needs. All my parts are for/from a 68 roadrunner.
I have a rear end with axles no chunk and leaf springs for B body FOR 140.00 IN NW GA
Not really looking for the housing as much as the diff itself. Currently have an open rear, and would really like to switch over to a sure grip.
Unless you know how to rebuild used, see Dr Diff for the third member.
Thanks for the tip. I can rebuild it myself but don't want to unless I have to. Was mainly hoping to find someone with a good one that they had changed for ratio purposes, not because it was whining or the like.
radiator
window cranks
Have a set of 906 heads that were gone thru, and never bolted on. $300.00 plus shipping from north central Indiana. PM with e-mail address for pictures.
