looking for engine
philm
11:40 PM
Wellington
Hi All
I am looking for a new engine for my 68 Satellite, I was about to rebuild the 340 that was in it,saddly my so called 340 turns out to be a 318, so no longer am I keeping it numbers matching and now keen to put a big block in it,but want something with good bits in it ,not just standard.
If any one has and engine or knows of one please let me know.
Cheers
Phil Mears:)
New Zealand (have shipping agent organised so freight no problem)
Years ago, Hot Rod magazine ran an article on how to build a 330 horse power 318. All I can remember is the recipe used a 318 block, 340 internals, 360 heads and some big thirty valves. The ultimate 318 sleeper, huh?
Blessings,
Shakota
shopguy
Senior Member
I have one, just fully professionall rebuilt. 69 steel crank, balanced, +.030, crower cam, eddy intake, B/E oil pan, never fired, never installed. Also have a matching 69 727 auto, fully professionally rebuilt, TCI valvebody. Never fired, never installed. $4600 for both, in NJ. Right in the 425 hp / 425 ft.lb range.
dont know what size engine or horsepower you are looking for
please give this individual a call
AES Racing in Buffalo Grove, IL USA
They can't build a good engine and will look for a core but you of course need a pocketbook with large bills.
if you were over my way i'd swing ya a 383 block with forged crank, forged pistons and forged rods..oh and pro gram 4 bolt mains.........rods and pistons are B/B chev...
for $450.........but alas......not far away tho.
Thanks for your reply's guy's
I have ended up buying a 512 ci with alloy heads etc,not what i set out to do, but you only live once,just got to explain to the wife about the hole in the bank account.
I know you are looking for a big block but I have a 69 340...
Engine:
9-18-68 casting
EW340P26760027
standard bore
steel crank that is turned .010 main & rods
factory rods and pistons 10:1
factory X heads
Crane hydraulic cam (150062)320 lift 284 duration
factory 4bbl intake
edelbrock carb
MSD spark plugs wires
you can hear this engine runs, still in the car.
Transmission:
small block 727
rebuilt to stock
I am selling the engine and trans together. The engine is still in the car so you can hear it start and run. Does'nt smoke at all..Any more questions feel free to ask or call 217-341-9571.
You dont half step do you? lol
