Manual 2 power steering
prib
3:54 PM
Hillsdale, In.
68 Satellite is the frame's mount for a manual steering box the same for a power steering box? Need to be sure before purchasing parts. Thanks
Yes they are the same mounting area, so is the pitman arm. Steering column shaft is longer for manual steering. Don’t bang on the end as it has plastic pins and it will collapse.
Yes, the same. FYI- You can cut down a manual steering column center shaft & make your own "plastic shear pins" out of hardware store plastic nuts/bolts (plumbing section) for use with power steering.
Good idea resourceful mopar nats this weekend hoping to find whole unit
