Highly modified crossram for wedge motors max wedge port. ( A&A unit )
intake only No carbs.
accepts both holley and carter carbs.
carbs have been moved in directly over the ports for instance throttle response just like the hemi crossrams.
carbs r raised 3/4" for more plenum volume (more power).
runners have been smoothed of casting flash inconsistency's . More power.
interconnect has been opened up, better AFR at idle.
equalizes fuel distribution across the plugs unlike originals that always fouls at least 2.
uses std linkage shortened for carb placement.
more valve cover clearance with the carbs inboard.
dont need bolt plugs anymore.
original hemi crossram carb plates.
racers r claiming over 100HP increase form these mods that r in the old direct connection books.
widely used in NSS racing.
2200.00 Shipped to the lower 48 ONLY.
