Max Wedge velocity stack seals
hatman426
12:33 AM
montreal quebec
hello i am finishing up a max wedge clone car i just received a set of reproduction rubber seals that go on under the hood for the velocity stacks to seal too does any one know how it was held on with could it be just glued on they look like they can go on two ways i try to add a picture the rubber seals are 7 inch hole my under hood is 8 inch which i thought was correct size for max wedge car and hemi thanks
every max wedge car I've ever seen , (an I worked on a bunch) never had the rubber seal on the hood , only the race hemi cars did and they were on the aluminum baffle that was bolted to the under side of the hood. the max wedge cars had foam on the stacks and the Hemi cars did not.
