FOR SALE (Miami, Florida) Small block parts from my '68 318 and '89 360 + 308 heads, etc.
cudak888
3:09 AM
South Florida
Feedback: +4 / =0 / -0
Starting to clean out all the bits and bobs from my '68 Satellite engine swap (and trying to raise a bit of play money for the carb, water pump, front accessories, radiator, etc).
These parts are what I've got - some of this is nicely itemized and photographed, some of it will take this weekend for me to get it out of the 318 and inspect condition (such as the crankshaft).
While I'd rather sell, I'm also open to trades in some cases, check out my build thread if you think you see something I need. I'm converting front accessories on my '89 360 to 1970+ specifications, so that's part of the consideration. Check out the build thread for more info: http://www.forbbodiesonly.com/mopar...e-4-door-light-refurb-and-big-fat-engine-swap
All parts ship from Miami, Florida via USPS for anything light or reasonably sized.
Heavy boxes go USPS Flat Rate or FedEx Ground as the case may be.
I'm linking to my eBay auctions for these parts, but you can ignore the prices you see there and the auctions themselves, for I will stop any of the auctions (with no bids - I will remove the links for auctions with bids) for any B-body member interested, and will sell the parts for the reduced prices I list here, not the prices I put up on eBay. That, and you can probably get a good idea of the shipping cost via USPS or FedEx, though I may have to charge a bit more, for I don't get the same shipping discount through PayPal that I do on eBay.
I also give a detailed description for each part in the eBay ads which should be more descriptive than the one liners below.
That said, prices do not reflect shipping. PM with list of parts you are interested in + your address and zip code for a quote. Address makes it easier for me to get an accurate FedEx quote for heavier shipments.
Payments via PayPal only.
That said, here are the parts:
LA 318 harmonic balancer (presumably original to the 318) - $10 + $12 Flat Rate shipping:
http://www.ebay.com/itm/141751045251?ssPageName=STRK:MEUNSOLD:IT&_trksid=p3984.m1562.l2649
Poly 318 or 273 / 318 1967 timing chain with bolt-on passenger-side pointer, $50 + actual shipping:
http://www.ebay.com/itm/141755434873?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Roller cam LA 318 or LA 360 oil-through pushrods, 6.740" in length. For 1988-1991 roller cam motors with roller tappets and LA heads with fixed rockers ONLY. Does not fit Magnums (if they did, I wouldn't be selling them) - $10 + $6 Flat Rate shipping:
http://www.ebay.com/itm/131581433890?ssPageName=STRK:MEUNSOLD:IT&_trksid=p3984.m1562.l2649
LA 360 "308" cylinder heads and rocker arms + shafts. $250 + shipping. Sorry, not discounting these due to the effort to pack and ship them:
http://www.ebay.com/itm/131587086043?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
http://www.ebay.com/itm/131587085543?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
LA 318/360 extra-long van dipstick - $10 + shipping:
http://www.ebay.com/itm/141754627341?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
LA 318/360 Denso alternator / A/C compressor bracket setup. May not fit older heads due to bolt requirements; came off of the 308 heads above. Should fit 302 heads no problem. $35 + 12 Flat Rate shipping:
http://www.ebay.com/itm/141754634468?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Crusty LA 318 rockers and shafts - $35 + shipping:
http://www.ebay.com/itm/141754692832?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Pre-1969 (no O-ring) single-point LA 273/318 distributor - $15 + shipping:
http://www.ebay.com/itm/141757582794?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
TBI-era fuel pump blockoff plate for 318/360 and any small block with the standard timing chain cover not including Magnums. $10 + shipping:
http://www.ebay.com/itm/131570784055?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
EGR valve off the '89 360 - $8 + shipping:
http://www.ebay.com/itm/141735886533?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
1962 Dodge Lancer / Plymouth Valiant 30 amp alternator w/Forward Look "V" logo at back - $25 + shipping:
http://www.ebay.com/itm/131587298583?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Crankshaft, pistons, rods, and main caps from the '68 318. They're all still in the engine, so I need to inspect them before declaring it all good for sale. However, provided everything IS good, prices will be $70 for the crankshaft, $80 for the set of 8 flat top pistons and rods, and $40 for the set of main caps. Plus, of course, whatever it costs to ship 'em. Pretty sure I can do $12 for a medium flat rate on the main caps. Pistons and crankshaft will require calculation.
PM if interested.
-Kurt
