FOR SALE - Milodon Big Block dual line oil system
gkent
4:45 AM
Ontario, Canada
Feedback: 4 / 0 / 0
Everything is BRAND NEW. It’s been installed on the motor and manually primed ONLY – never run.
Here’s what you get:
Milodon oil pan p/n 31470 (see actual specs below)
Milodon swivel pickup p/n 21330
Milodon hard line to dual line adapter
Milodon dual line adapter p/n 21350
-12 AN fittings and braided hose
Milodon long pump drive shaft (bronze gear for solid roller cams)
There is over $950. Worth of stuff here and its all BRAND NEW
BONUS
*The internal corners in the 90* elbows have had the sharp machined edges taken off and blended. All inlets or outlets on the elbows have been radiused. All this is done to reduce cavitation and improve flow which results in less strain on the pump drive and cam gear as well as a (minimal) HP gain.
*The bronze gear has been machined to take a Torrington steel washer between the gear and block bushing. This virtually eliminates wear in this area which is very common when the bronze gear is allowed to run against the bronze bushing (similar metals !!)
*The pickup has been installed PROPERLY and does not leak (the trick is pipe sealant on the fittings and O-rings inside the pan – no need for messy silicone)
Note: the assembled photo is for reference only. This sale is for ONLY the items in the other photos.
The sale does NOT include a pump or pump cover.
Reason for selling: change of plans.
Might be will to seperate
$750. U.S. plus shipping
Item is located in Canada - the best and least expensive shipping method is MAIL
Oil system 002.jpgDSCF4432.jpgDSCF4433.jpgDSCF4434.jpgDSCF4443.jpgDSCF4445.jpgDSCF4446.jpg
