FOR SALE Mopar 426 Hemi Engine Fresh Build
challengersteve
10:52 PM
alma arkansas
Feedback: 18 / 0 / 1
I am selling a fresh brand new build Mopar 426 Hemi.
This is NOT a crate engine it is a custom build NEW engine built by legendary Hemi Guru Jim Hale.
This started as a new bare 426 Hemi unmachined block. These blocks were sold unmachined to racers back in 90-92.
They were only partially machined with unfinished bores and no lifter holes. Jim machined all lifter bores and then they were all bronze bushed.
All bores were custom finished. Line bore was finalized and all deck surfaced squared. This is the final custom machine with that is never done with a generic “crate” engine.
All internals are new, Block brand new, brand new steel 8 bolt Hemi crank, new h beam rods, new pistons, new Edelbrock heads with custom valve job, new valve springs, new Comp Cams true solid lifter cam with real Mopar nos lifters, rebuild store stock rocker arms.
Everything is standard bore, standard crank, etc.
The carburetors are brand new 750 Edelbrock units that have been jetted to match the intake and cam combination.
The intake is a vintage Edelbrock Rat Roadster that has been modified by Jim to make a flatter torque curve.
There is only dyno time and the engine made 505 hp and 489 torque and had a lot more if you wanted to tutu it up higher.
The block and tin were painted in epoxy sealer then ppg Hemi orange base clear.
It was balanced using a thin harmonic balancer to you can use the cheaper wedge pulleys.
The price is 38,500 and I am located in Van Buren, Arkansas.
