themechanic
Oklahoma is OK
- 8:12 PM
- Nov 11, 2012
- Moore, Oklahoma
At least the young feller is interested in Mopars. He's got a super nice Dart, too.Needs to lose the man bun .. very interesting !
They acknowledged the blow-by issue and mentioned making a future video after fixing it.ABSOLUTELY needs to loose the "man bun" maybe a hair cut as well......overall, interesting but I'm still dubious. Just wondering how much additional HP could be realized if they fixed the blow by.....look at the vent on the rocker arm cover when near max load ..... looks like a lot of blow by to me.....
BOB RENTON
Well I can tell you this I put an MSD 6AL box on my 63 and used to have the MP orange box on it. The car is no faster at all with the MSD but I like the MSD as it keeps the plugs cleaner where I can run them for well over a year. Ron
Leave a comment on the video. I'm sure they'll get back to you.I would like to find out what the inlet air temperature and oil temperature was for each run.
I suspect the dyno number differences were more a result of these two factors than anything.
When I switched from a Mopar Orange box to a MSD street fire I had to turn the timing back as my 383 started to ping.
No other changes.
It definitely started better and had better low end response.
I don't believe any of these are multiple spark discharge units.
No other changes.
They didn't run any tests with a MSD box:Are you saying an MSD 6AL is not a multi spark? The Mopar orange box sure isn't.
IMO....at RPMs in excess of 3000, MSD (Multiple Spark Discharge) boxes simply do not have enough time to generate more than one spark per cylinder, although, the spark generated can be of a higher voltage depending on the coil's design and its turns ratio (primary to secondary or voltage applied to the primary winding resulting in the secondary voltage produced). One could observe the high voltage spark waveform using a storage oscilloscope, to watch the shape (amplitude and voltage) and number of pulses (time base) that occurs as RPM's increase. And then compare the control box's ability to work as intended or desired..... Just a thought....They didn't run any tests with a MSD box:
Proform orange
Mopar Chrome
FBO
Revinator
Don, maybe I didn't read your post correctly.
But a MSD will start and run a bit better than most others. Again my antique MSD 404 BC would fire the plugs to very high RPM. My observation was that the Mopar orange box cars ran out of steam by 6000 RPM. My blue box went past 7000 & the MSD well past 8000 RPM.
