FOR SALE MOPAR,ENGINES ---BIG BLOCK,+intakes,heads,383,440-413,+ more
joel
7:04 AM
edinboro pa
Feedback: 20 / 0 / 0
MOPAR,ENGINES ---BIG BLOCK,+intakes,heads,383,440-413,+ more -
1965 383 shortblock,, seized from sitting clean,, 6-16-65 250.oo
65 413 block dated 4-2-64 no caps 100.oo
HEADS
452 heads rough cond, 100.oo pr
346 heads may or may not need rebuilt 75.oo pr
INTAKES
62-67 383 iron intake #2205968 100.oo
67-69 440 intake # 2806178 i have the following dates
5-18-68
10-11-67
100.oo
thermoquad iron intake 20.oo
67-69 440 iron intakes many to choose from 100.oo
66 440 intake # 2206000 100.oo
65 413 intake # 2206000 100.oo
70 440 iron intake #2951736--dated8-23-69 125.oo
72 factory dual plane iron intake#3614014 25.oo
VALVE COVERS -BIG BLOCK
69 440-383 h.p. nice 125.oo pr
71 set 50.oo pr
72 set 100.oo-blaseted primed
many more 25.oo pr
no 70s
water pump housings BIG BLOCK
big block water pump housings original iron diff cast #s avail.
67-70 383-hemi water pump housing #2780987--100.oo
big block 4 groove crank pulley for steel crank 40.oo
air cond pulley and bracket for big block steel crank motor 40.oo
BIG BLOCK non h.p exh. manifolds 50.oo pr many to chosse from
stock rocker shafts 10.oo ea
stock rockers 10.oo-set
stock rocker spacers 10.oo-set
stock bolts and special spacers 10.oo set
located in n.w. penn
edinboro pa 16412
joel, Apr 19, 2017
I have a 11 inch and a 10.5 both for a steel crank 75.oo + s.h.
if your interested let me know your zip and I can tell you s.h. thanks, joel
Do you have a flex plate for a wide ring gear 10" torque converter?
Needing a 440 forged crank. Do you have any of those for sale?
I don't have any steel cranks
how do I tell if a flex plate is for a wide ring gear
The lightening holes won't be round, but almost triangular. The bolt holes for the torque converter will be 10" measured to the opposite hole.
The flex plate on the back of the '77 truck 440 you have listed is what I need. Just not that particular one pictured, cause it's been bent.
i do have another one , in nice cond , not bent
10.oo +10.oo s.h.
check or m.o. are fine I don't have paypal
joel horoschuck
19511 irish road
edinboro pa 16412
please include a ret. addr. and which part you are buying on a note, thanks, joel
Any chance you could send me a pic so I know it's what I want?
heres some pics of the flex plate and the 2 groove w.p. pulley
