Mopar Performance Valve Covers
Houle #382
12:14 AM
Hastings NY
I'm looking to purchase a set of the Mopar performance Valve cover P5007611AB . These are the aluminum finned covers. Will the twist on breather cap P4529880 work on these covers and what grommet will I need to put into the other oil filler hole to put my PCV valve.
I think I found what I'm looking for, It's a Scott Drake twist in grommet for the PCV valve. Read the reviews and some Mopar guys used them on their Mopar Performance Valve Covers and they worked perfect and didn't have to do any drilling. I will reply back here when I get everything from summit this coming week.
Any pics and what grommet part number did you use? I’m in the same situation.
Google, Scott Drake Valve Cover Grommet C7AZ-6892 Summit Racing has them for $5.85. You will have to trim 2 of the tabs a little with a razor blade then it fits perfect. I also ordered a Mopar twist in air breather and I had to make a gasket out of cork so it would fit tight. So far it's been perfect no issues
