motor plate bolts
moparmarkk
11:43 AM
panhandle fl.
Hi, anybody out there know of a kit with bolts or studs for putting a motor plate on a big block mopar? (water pump-motor plate - block) thanks mark
when i did mine i went to a bolt supply for all the bolts i needed.
I definitely suggest studs, so that the water pump can be removed without the engine falling out the bottom, lol. I had a lathe and bar stock, so I just made what I needed, but you should be able to get what you need from a bolt specialty shop, or somebody like McMaster Carr.
Worst case, cut threaded rod to length.
Look for a good bolt supplier, One with USA bolts. Good hardware store studs should be good for a water pump. That's not a high stress area.
on all mine the bolts for the mount plates go thru the water pump housing and water pump is easily removed without removing any mount bolts
