Texas charger 73
On my 73,318 charger I want to put in an msd ignition system. I know factory creates enough spark, but I want to eliminate the weak links(ecu,ballast). Is this easy to install? What all wires can I remove after installing?,
Second I was told I would be better off with a one wire alternator opposed to a factory 3 wire and yet again I could clear out more in needed wires. Who has done this mod? Improvement? You like it better than 3 wire? Is one wire still a dodge alternator?
Along with these improvements being upgrades o want to clean up engine bay removing un needed wiring.
