SOLD MSD Shift Light 8952
RJS
1:14 AM
new jersey
Feedback: +17 / =0 / -0
One (1) MSD Shift light #8952
Works perfect just removed couple of weeks ago
Cost 156.95 new @ Summit
Price $50 plus shipping in US Only
Brand:
MSD Ignition
Manufacturer's Part Number:
8952
Part Type:
Shift Lights
Product Line:
MSD Shift Lights
Summit Racing Part Number:
MSD-8952
UPC:
085132089529
Shift Light Diameter (in):
1.500 in.
RPM Activated Switch Required:
No
RPM Activated Switch Included:
No
Adjustable:
Yes
Adjustment Style:
Pills
Shift Light Lens Color:
Red
Shift Light Housing Color:
Black
Lens Cover Included:
No
Overall Length (in.):
4.500 in.
Quantity:
Sold individually.
MSD Shift Lights
MSD shift lights have a built-in rpm sensing circuit that will turn the light on when the engine reaches the desired rpm. The rpm is chosen with MSD plug-in modules. They feature a bright cluster of LEDs, making them easily visible, even in broad daylight. The lights also turn on for a second or two when the ignition switch is first turned on, to inform you that they're functioning properly. The Shift Lights will work on 2, 4, 6, or 8-cylinder engines. They plug directly into the tach output on MSD 6, SCI, 7, 8, and 10 Series ignitions, or can be connected to the negative coil terminal when used with points or inductive-type ignitions.
