Multiple performance parts ( not mine)
69 340 BLOCK/CRANK/RODS, BORED 30 OVER, NEEDS REBUILD, $1200/ALL
NEARLY NEW MOPAR PERFORMANCE TORQUE DRIVE FAN PACKAGE, $75
EDELBROCK 340 TORKER INTAKE, RECONDITIONED, $179
EDELBROCK 440 TM7 INTAKE,RECONDITIONED, NICE $199
EDELBROCK 440 TORKER INTAKE, RECONDITIONED, $199
EDELBROCK 440 TORKER 2 INTAKE, $179 AND ALSO 1) CERAMIC COATED, $245
EDELBROCK VICTOR 440, USED FOR DYNO ONLY, $299
EDELBROCK LOW RISE 2X4 440 INTAKE/CARBS/LINKAGE/AIR CLEANER, NICE $1100
MOPAR PERFORMANCE P5153525- NO LONGER AVAILABLE- LIKE EDELBROCK PERFORMER RPM 440, NEW, $325
WEIAND 440 TUNNEL RAM 5987, CERAMIC COATED, 2X4 WITH EDELBROCK 600 CARBS, LINKAGE AND AIR CLEANERS, $895
WEIAND 340-360 XCELLERATOR SINGLE PLANE- HIGH RISE, NICE, $179
MOPAR M/T VALVE COVERS FOR 440/383, POLISHED BUT NEED CLEANUP, $125
MOPAR M/T VALVE COVERS FOR SMALL BLOCK, NOS POLISHED- NEW IN BOX- HAVE SOME SHELF WEAR, $275
MOPAR M/T VALVE COVERS FOR SMALL BLOCK, GOLD PAINTED, NICE USED, $110
MARCH SMALL BLOCK SERPENTINE WATER PUMP PULLEY, $50
BIG BLOCK AND SMALL BLOCK CRANK AND WATER PUMP PULLEYS, OEM V BELT, $50/1
440 ROLLER CAM DISTRIBUTOR/OIL PUMP DRIVE, BRONZE, NEW $99
MSD DISTRIBUTOR FOR 440 -BILLET, NICE USED, $225
MALLORY UNILITE 440 DISTRIBUTOR, USED ONLY FOR DYNO, $245
HOOKER 5901 SUPER COMP HKR HEADERS FOR 440, CERAMIC COAT, $650
HOOKER COMP HEADERS, BLACK PAINTED, NEW, $275
PRW 383-440 ROLLER ROCKERS AND SHAFTS, NEW, 1.5, $299
HOLLEY 850DP CARB, LIKE NEW, $299
EDELBROCK 600 AND 750 CARBS GOOD CONDITION- 125-UP
CUSTOM DRIVESHAFTS- MADE TO ORDER WITH ALL NEW JOINTS, AND NEW SLIP YOKE, $549
71-4 B BODY BIG BLOCK DRIVESHAFT, 50.68" W/ 7290 JOINTS AND SLIP YOKE, FOR 8 3/4 &A833 4 SPEED AND 727 AUTO, $275
HD SUPER STOCK A BODY, B BODY, E BODY LEAF SPRINGS, NEW AND USED- CALL
BIG BLOCK POWER STEERING PUMPS - WITH BRACKETS ,PRESSURE HOSE, AND PULLEYS, $175-UP
****62-69 B BODY REBUILT 4 SPEED TRANSMISSION, $1400 ALL NEW PARTS
****66-76 A BODY 4 SPEED TRANSMISSIONS, REBUILT $1400
****70-4 B/E 4 SPEED TRANSMISSION REBUILT, ALL NEW PARTS $1500
****62-69 B BODY HEMI 4 SPEED, COMPLETELY REBUILT, $2595
****70 B/E HEMI 4 SPEED 18 SPL TRANSMISSIONS, REBUILT, $2695
67 440 BIG BLOCK BELLHOUSING,11", NICE, CLEANED AND PAINTED, $550
67-9 383-440 A BODY BIG BLOCK 10.5" BELLHOUSING, NICE, CLEANED AND PAINTED, $550
69 440 BIG BLOCK BELLHOUSING, 11", MINT, CLEANED AND PAINTED HEMI ORANGE, $595
70-74 BIG BLOCK BELLHOUSING, #513, NICE, $450
69-72 SMALL BLOCK BELLHOUSINGS, $225
66-74 A/B/E 4 SPEED Z BARS AND FORKS, RECONDITIONED, $79/1
66-70 B BODY 4 SPEED PEDALS, RECONDITIONED WITH ALL NEW PARTS, $395
67-76 A BODY 4 SPEED PEDALS, $245-UP
PROBLEM SOLVER ROLLER PILOT BEARING- FOR USE IN CRANKS THAT ARE NOT DRILLED DEEP ENOUGH IN MANUAL TRANS APP, $22
****COMPLETE AND PARTIAL 4 SPEED CONVERSIONS FOR A/B/E BODY CARS- CALL****
4 SPEED LINKAGES, ALL BODY TYPES, $ CALL
LAKEWOOD AND ANSEN BIG BLOCK AND SMALL BLOCK SCATTER SHIELDS, GOOD CONDITION, SOME WITH BLOCK PLATES, $295-UP
3.23/489 CASE SURE GRIP REAR CENTER, GOOD USED, $650 (MORE RATIOS AVAILABLE)
****8 3/4 REAR CENTER SECTIONS, ALL NEW 489/742 CASES- ALL NEW GEARS/POSI/TIMKEN BEARINGS/SEAL/CRUSH COLLAR ELIMINATOR KIT FOR 489, CHOICE OF 7260 OR 7290 YOKE, $1249 FOR POSI, OR SPOOL $1199, FOR TRU TRAC $1349 , ADD $99 FOR U BOLT YOKE
****CUSTOM BUILT 8 3/4 AXLE ASSEMBLIES FOR A/B/E BODY CARS/ STREET ROD/TRUCK- ALL NEW COMPONENTS: NEW AXLES, POSI, GEARS, BEARINGS, SEALS AND GASKETS, BRAKES (WHETHER YOU CHOOSE DISC OR DRUM- INQUIRE), BRAKE LINES/VENT/HOSE/TEE AND FREE POWDER COATING TO PRESERVE YOUR INVESTMENT. STARTING AT $2199 W/ POSI OR SPOOL, $2299 W/ TRUTRAC , OR BLACK BEAUTY WILWOOD PACKAGE REARS START AT $2699 COMPLETE
****CUSTOM BUILT DANA 60 REARS WITH ALL NEW PARTS/NEW STRANGE S60 HOUSING-**** FOR A/B/E BODY CARS/STREET ROD/TRUCKS/GM/FORD, $2399 FOR POSI OR SPOOL, $2799 FOR TRU TRAC- ALL OUR REARS HAVE PROVISION FOR PINION SNUBBER AND HAVE FREE POWDER COATING TO PRESERVE YOUR INVESTMENT. CHOICE OF DISC OR DRUM BRAKES. BLACK BEAUTY PACKAGE REARS WITH WILWOOD BRAKES ARE $2799 -UP
A- BODY 8 3/4 30 spl AND DANA 60 35 spl AXLES, W/ 4.5" BP, COMPLETE WITH BEARINGS INSTALLED AND GASKETS- READY TO USE, $439/COMPLETE
GREEN AXLE BEARING SETS, $99
DANA 60 DETROIT LOCKER, GOOD USED, 30 SPLINE, $450
NEW POWER LOCK DANA 60 DIFFERENTIALS, 35 SPL, MADE IN THE USA! $499
NEW POWER LOCK 8 3/4 30 SPL DIFFERENTIALS, 30 SPL, MADE IN THE USA! $440
NEW DANA 60 WORM GEAR TRU TRAC POSI 35 SPL- MADE IN THE USA! 1200HP CAPACITY, $599
NEW 8 3/4 WORM GEAR TRU TRAC POSI 30 SPL- MADE IN THE USA! 800HP CAPACITY, $549
NEW GEAR SETS FOR 8 3/4 AND D60, $229-UP
NEW MASTER SETUP KITS FOR 8 3/4 AND D60, $129-UP FOR 8 3//4, $179 FOR D60
A-BODY 340-360 TORSION BARS, NICE USED, $145/PR
70-2 B/E BODY FRONT SWAY BAR OEM WITH BRACKETS, $125
70-2 B/E K FRAME ASSY, GOOD CONDITION, $250
70-2 B/E 6 PACK K FRAME ASSY, GOOD CONDITION, $375
71-2 RR GTX FRONT BUMPER, OLDER RECHROME, $395
71-2 RR GTX SATELLITE DOOR SILL AND 1/4 WINDOW STAINLESS TRIM, RARE, 4 PC SET, $650/ALL
71-4 CHARGER FRONT SPOILER, REPRO, NEW, $125
71-4 B RALLYE DASH CLUSTER, NICE , NOT CUT, 150MPH, $275
72 RR REAR BUMPER, NOS, $995
72 CHARGER RALLYE DOORS- HARD TO FIND- NEED WORK BUT USABLE- $1500/PR- PICS AVAIL
73-4 CHARGER LH FENDER, PRETTY SOLID, HAS SOME DENTS, $450
