FOR SALE ****MUST GO **** Charger parts
black68
6:24 AM
illinois
Feedback: 1 / 0 / 0
COMPLETE front end ( k member, suspension parts)
stock intake manifold
stock heads
stock 383 valve covers
used 383 headers ( needs media blasting, rusty )
used fan off a 383
steering gear with pitman arm
Saginaw power steering pump
steering wheel horn ring
steering column- column shift- ( with aftermarket wheel)
Emergency Brake pedal
rear window glass ( used )
used alternator
Front seats
rear bench ( both pieces)
lower a/c vents ( PAIR )
dash pad with a/c vent (2 broken tabs) - **SOLD**
dash a/c selector
used ( rough with cracking) dash pad
radio speaker knob and plate
OEM used brake booster
8.75 complete rear axle - 3.23 ratio
original rear leaf springs
stock radiator
used 5x4.5 bolt pattern vector style wheel set ( widened lug holes , wide rears)
individual ralley gauges
Tic Tok Tach - **SOLD**
Ralley dash clock ( 2 total )
Speedo
Vacuum pods ( 4 total )
gauge cluster parts
sun visor set ( some stitching coming loose)
fenders ( driver & pass ) spots need repair
4 spd console ( originally tan, painted black
chrome console side trim
console side lights
4 spd console brackets ( Brand new AMD)
Back chrome console plate
glove box door ( needs dye job)
used original parking lens set
68 chrome ribbed console top - 3 piece set - ( good amount of pitting )
driver & pass door top pad
inner windshield trim to headliner
dome light
rear bumper ( great core, needs refinishing )
original used hood turn signal lens and bracket set
68 charger grille support
ash tray assembly
upper quarter window pad set ( needs refinishing )
a link for all the parts I currently have pictures of:
http://www.flickr.com/photos/93359881@N06/sets/72157638378349525/
pm sent
Looks good what are you asking for
the console tops 3 pieces as well as the hood turn signals and chrome console back plate?
stock heads
used fan off a 383
power steering pump brackets ***SOLD***
used alternator
Front seats
dash a/c selector
stock radiator
individual ralley gauges ***SOLD***
Ralley dash clock ( 2 total )***SOLD***
Speedo ***SOLD***
Vacuum pods ( 4 total )***SOLD***
gauge cluster parts***SOLD***
chrome console side trim***SOLD***
console side lights***SOLD***
4 spd console brackets ( Brand new AMD)***SOLD***
Back chrome console plate***SOLD***
driver & pass door top pad***SOLD***
dome light
ash tray assembly
Original chrome auto console shifter
Auto shifter console top w/ indicator
http://www.flickr.com/photos/9335988...7638378349525/
COMPLETE front end ( k member, suspension parts) - 450
stock intake manifold - 65
stock heads - 85
stock 383 valve covers - 25
used 383 headers ( needs media blasting, rusty ) - 50
used fan off a 383 - 15
steering gear with pitman arm - 100
Saginaw power steering pump - 40
steering wheel horn ring - 25
steering column- column shift- ( with aftermarket wheel) - 150
Emergency Brake pedal - *** SOLD ***
rear window glass ( used ) - 100
used alternator - 25
Front seats 175 ( each )
rear bench ( both pieces) 175 ( each )
lower a/c vents ( PAIR ) - 40
dash a/c selector - 100
used ( rough with cracking) dash pad - 25
radio speaker knob and plate - 50
OEM used brake booster - 30
8.75 complete rear axle - 3.23 ratio - 250
original rear leaf springs - 100 ( set)
stock radiator - 30
used 5x4.5 bolt pattern vector style wheel set ( widened lug holes , wide rears) - 400
Speedo ***SOLD***
sun visor set ( some stitching coming loose) - 35
fenders ( driver & pass ) spots need repair 150 ( each )
4 spd console ( originally tan, painted black - 250
glove box door ( needs dye job) - 75
used original parking lens set - 25
68 chrome ribbed console top - 3 piece set - ( good amount of pitting ) - 125
inner windshield trim to headliner - 65
dome light - 30
rear bumper ( great core, needs refinishing ) - 150
original used hood turn signal lens and bracket set - ***SOLD ***
68 charger grille support - 100
ash tray assembly - 45
upper quarter window pad set ( needs refinishing ) - 200 (set)
Original chrome auto console shifter - 50
Auto shifter console top w/ indicator - 60
stock heads - 85
used ( rough with cracking) dash pad - 25 ***SOLD***
stock radiator - 30 ***SOLD ***
Speedo ***SOLD***
4 spd console ( originally tan, painted black - 250 ***SOLD***
dome light - 30
68' charger torsion bars ( set ) - 50
stock heads - 85
Speedo ***SOLD***
dome light - 30
ash tray assembly - 45 ***SOLD***
I am interested in as much of a complete 4 speed console and mounting brackets if you still have it
Sorry no its all gone. I will post an updated list
ANY FRONT END SUSPENSION PIECE - TBD
stock heads - 85
Speedo ***SOLD***
dome light - 30
stock heads - 85
Front seats 175 ( each *** SOLD ***
rear bench ( both pieces) 175 ( each ) *** SOLD ***
Speedo ***SOLD***
dome light - 30
stock heads - 85
dome light - 30
***NEW ADDITIONS ***
used original splash guards ( front corners under frame rails)
stock used 727- 8.75 drive shaft
stock heads - 85
dome light - 30
