Name that part for a 1969 Dodge Charger
Kennith
8:24 AM
Nashville, Tennessee
I got a box full of parts with a 1969 Dodge Charger and I’m trying to figure what some of these are.
If you can help it would be appreciated
in pic one those rod supports mite be the ones that bolt to intake n rear of A/C compressor,pic four is a brake booster bracket,rest i have no clue,by pics not sure if for a 69 charger or not,check for part #
The adjustable rod in the first pic like like a throttle linkage.
The other plates? Maybe from a pulled apart brake pedal assembly or e brake assembly?
RV2 A/C support bracket and rods? Piece on the outside right is the kick down linkage rod from top of rear of motor down towards transmission
two pieces that look similar are for 72-ish and later motors...throttle brackets. V looking piece mounts at the front on the LH front of intake and the throttle return spring run to it.
Not 100% sure on this one but would guess power steering bracket? Or for some portion of the accessories on the front of the motor...Alter, AC, idler, PS etc?
Looks like an alternator bracket for an A/C car, mid 70's maybe.
The welded nut is for the heater hose holder.
Most, if not all of those parts don't belong on a '69 Charger. Probably all came from a truck.
3 rods goes under dash at drivers side.
I initially though so too, but it's been a long time since I have been under the dash of a B-body. What made me question my initial thought was the bracket the 3 rods were tied to, could not place that bracket under the dash.
I appreciate everyone's help. It is hard to put something back together that you did not take apart.
I figured they gave me parts for another car when I found an in cabin hood release.
I am still trying to find the bolts to put the windows back in the car.
Thanks everyone.
The rods are under dash support. The brackets are unique to a big block with AC. That short 3 point bracket is AC only and might be for the alternator. I see a throttle spring bracket. Firewall stiffener plate for brakes. What appears to be a 70's small block throttle pressure and cable bracket.
