Magnes
- 9:22 AM
- Nov 14, 2013
- in the Houston Texas area
I am looking for the following from a 71 or 72 Satellite/RR/GTX:
1- Driver's side headlight bezel (grill piece) (not the 72 RR piece)
1- Grill center section - (not the 72 RR piece) - I am OK with having to fix a broken slat or 2 but the piece cannot be warped badly. Prefer good and solid as is.
1- Driver's side door mirror mounting plate. It is the small mounting plate that is located on the inside of the door, has a single screw on the outside of the door that holds the plate in place (along with one tab that keeps it centered), and then it has the 2 threaded holes by which the side view mirror screws through the mirror, through the door, and into the mounting plate. I really only need that mounting plate, and maybe the screws if you want to throw those in.
PM me for quickest response. Thank you
