Need assistance with small block 360 heads
dodge1972
3:54 AM
Aurora, CO
Purchased a pair of new small block heads 20 years ago. Part number is 4532287. Maybe 4532281. Unable to locate the specs. If you have additional information, I would appreciate it. Thanks
4532287 is a Stage V, stock valve Big Block head. 4532281 doesn't seem to come back to anything.
he said part number
what's the casting number dodge1972
describe the combustion chamber- wedge or open
intake ports 273318 size or 340-360 size
what else?
Heads with the “casting number” 4532287(the number cast into the head. This is NOT the “part number”) are as mentioned..... stage v BB heads with an exhaust crossover.
I’m pretty sure the same casting is used for both the std valve size and 2.14/1.81 versions.
“Part Numbers” (the number on the box)would be:
P4529992 - std valve sizes
P4529993 - machined for 2.14/1.81 valves
A few pics should clear it right up.
Just wanted to thank everyone for your responses. sent the heads to machine shop for springs, seats and new values.
Hey man, you've been here long enough to know better.....no pics, it never happened! lol :D :D :D
Thanks again for replies. Purchased several years ago at a swap meet. Seller marked the box at 360 heads. Thus the confusion. That's for responding.
