Need driver side lower door hinge
BigYellaStella
1:28 PM
Ohio
Mine is fubar, posing when opening and closing, the pin appears to be broken and the spring is akimbo. Anyone know where to get one? Rebuildable?
You should be able to get a pin and bushing kit for both upper and lower hinges from any decent parts store Napa ect. Unless the hinge itself is broken it will re bush and a couple new pins.
If you don't have access to a door jack you can get by using a floor jack and a piece of foam ect for a pad when you pull the door off.
take a marker or grease pencil and make some ref marks on the bolts and hinges then keep the bolts straight as far as position on reassembly , marks will get you close on adjustment you may have to move it a little but you should be close.
I have a lot of good used hinge cores. Send me a message with year model
