need HELP 73 charger 318
icecat66
3:14 PM
Bloomsburg pa
Need help motor will crank like hell but no spark at the plug I didn't take it apart but dad and I put it back together and like I said crank like hell won't even try... pulled number one out set TDC and cranked again nothing pulled the plug and don't see any arch on the plug.... any info is greatly appreciated
Thank you
Joe
Danville PA
Points? Electronic ignition? Just off the top of my head coil, ballast resistor or ignition condensor if no spark at the plugs. Do you have spark at the coil? Voltage to the coil? Ballast resistor? You said it will crank so it's not the neutral safety switch. Check for frayed/broken wires at the coil and ballast resistor.
Electronic ignition yes.... coil swapped it out.... green wire going to could is frayed a little put electrical tape on it...
