Need help sourcing ps pulley
Huicho417
2:34 AM
San Antonio , Texas
I switched the steering gearbox on my 1967 Coronet several months ago to the quick ratio Borgeson upgrade sold by Bergman. I did leave my original TRW ps pump and added a fluid cooler. For the most part it was great except the noice when trying to park in a tight spot. I finally made the decision to purchase the Saginaw type pump also from Bergman with correct bracket for my 318 with water outlet on drivers side.
Here’s the issue, I cannot find the pulley for this new pump. I spoke to Peter and he said they are hard to find. I need a 5/8” keyway pulley approximately 5 1/8” outer diameter to work with my v belt. Any ideas where I can find one? It’s possible that it may have to be a different outer diameter as long as I can find a v belt to make it work.
