Neutral safety switch
Data Plate
7:37 PM
New York
Is a 1967 68 and 69 727 neutral safety switch all the same or was the earlier ones different from a 69
'67 is a single-pin; late '68 and up is a 3-pin.
If my transmission is a 67 can I put the 3 pin in it because my wiring is 3 pin will it work correctly
Probably a different actuator "comb" in the transmission.. this is for the three pin neutral / reverse light switch.
My cars a 69 but I believe the transmission is a 67 or 68 when I hook it up and put it in drive the reverse lights stay on don’t come on in park or neutral just come on in reverse and the forward gears does the transmission have to be pulled out again to fix it
