SOLD New Carbs, Scarce Intakes, Fancy Air Cleaner
Slantsixdan
4:50 PM
Vancouver
Feedback: 2 / 0 / 0
••• New carburetors •••
One brand new (not "remanufactured") Stromberg WW3-272 2bbl, OE on 1967 318. Will fit either of the intakes below, or any Super Six intake, or a 273, 313, or 318. Atmospheric bowl vent (no hookup for charcoal can).
$225 plus the ride from Seattle.
One brand new (not "remanufactured") Carter BBD-6225s (now I ask you, how can you not love that carb ID number?) with integral electric choke. OE on 1973 heavy-duty truck 318. Will fit either of the intakes below, or any Super Six intake, or a 273, 313, or 318. Atmospheric bowl vent (no hookup for charcoal can).
••• Intake manifolds •••
First, the yellow one. Factory Chrysler Australia item, 1967-up. Casting № A2626 246 (Guess what "A" stands for!). This is similar but not identical to the US-made '67-'75 export 2bbl intake. I ran it with good success on my '65 for about 8 years with a Stromberg carb just like the one listed later in this same ad. Took it off when the intake-to-exhaust manifold "hotbox" gasket failed (Remflex wasn't yet available at that time) — that's why there's soot all over the bottom of it. It'll clean up well; that's multiple coats of baked enamel on it; I know because I painted it and baked it myself in the kitchen oven (windows wide open and the house still stank of paint!). $225 plus the ride from Northern Michigan.
Next, this blue intake is a Chrysler Marine item, № E-7768-M with water heatbox № 3609 183. Cleaned and painted Chrysler Blue. If you want to use this one in a car that has any vacuum-operated accessories (heat/AC, power brakes, etc) you'd want to drill and tap for a vacuum nipple on the rearmost runner. The pad is there, just not drilled/tapped like on the passenger car intakes.
$275 plus the ride from Northern Michigan.
••• Air cleaner •••
Here's a byooteeful Argentinian high-perf 2bbl air cleaner from a Dodge 3700GT. Powder-coated gloss black; it won't flake off like paint. It was a bit dusty from sitting on the garage shelf; I sprayed glass cleaner on a paper towel and gave it a quick wipe, that's why there are some wipe-streaks and water drops in some of the photos. It's an offset air cleaner to leave room for an air conditioning compressor. It's also a low-profile air cleaner so you get to close the hood!
$149 plus the ride from Seattle
Yellow Australian intake, air cleaner, and Stromberg WW carb are sold. Blue marine intake with water box and new Carter BBD carb are still available.
