Newby
Ding's Garage
2:27 AM
Brainerd Minnesota
Hello I am so new to this site the ink is not dry. I am on a mission to have a max wedge clone. You guys will have a wealth of info I need. I do have a 440 block heads etc . It will have a cross ram. I am on the hunt for a 62 or 63. They are good looking cars no matter what the other people think. So here I go baby steps.
Welcome to FBBO! Enjoy all the information as well as the jokes on here!
:thumbsup:
Welcome from Ohio. Hope you’re successful.
You cans sometimes find those cars on this site. FYI- to use a 440 a max wedge cross ram intake, you'll need max wedge heads (MUCH larger ports vs. 440) and be very careful about piston selection since the max wedge heads have larger valves. You might check into Indy cylinder heads (?) since I think they've got some aftermarket max wedge heads (race) and even if you're going for stock type heads, they can probably give you some guidance on piston selection.
welcome to FBBO good luck with your search and keep us posted
Welcome. They are so ugly they are cool. Good luck on your quest. Everyone is always on here to help each other out when needed.
Hi and welcome aboard!
Thanks for joining the Forum
I currently own two 1963 Dodge "B-bodies"
Also have the 440 based Max Wedge style engine and trans if your interested
Thanks again for joining the forum
Welcome to FBBO from NorCal Sierras
good luck
with the 62-63 search & Max Wedge clone build
:welcome::usflag:
Good luck in your search. They're out there!
Greetings from central Illinois. There are a few of us here that have put together clone max motors and original motors. When it comes time , we can help you. Just have to figure out what you want to do with the car street or race. Get ready to spend some $$$$
Hello & happy hunting/gathering! & Building.
