Newby
Ding's Garage
5:21 PM
Brainerd Minnesota
Hello I am on a mission for a max wedge clone . I want to have a motor built. I live next door to BIR in Brainerd Mn. I here a lot of comments about builders. The ones I here about are there with there cars. KRTE was there during the nationals. They are probably all good. I am on a learning curve. Any input? Thanks
Welcome to the dark side. I cannot recommend a builder but there are plenty of folks here who can. You may want to post in the 62-65 or engine forum on FBBO. Good luck.
Is money no object? Do you have anything to work with or are you starting from scratch? And welcome to the site!
Hi and welcome aboard
uh, GEE....
I'm selling a 63 dodge Polara all stripped, bead blasted, primed, ready for paint....
And another GREAT 4-door for X-tra parts, and a super 727 built by a pro for performance/strip and a incredible 440 built Maxie Clone engine built by the famous Dale Reed of Baldwin Park, CA
(He builds ALL of Bob Mosher's engines)
PM if interested.....
Bob Mosher/Dale Reed:
Dale Reed:
Dale Reed:
Again, thanks for joining the forum!
Welcome! I would just try to make sure whoever you use has a good mopar reputation....lots of good builders that do chev/ford stuff sometimes miss the little details that are unique to mopar engines...Brainerd huh...bundle up!:D(wife's family is from Lake Park..brrrrr)
Welcome from Ohio & good luck on your quest.
What year car are you looking at for your clone? There are a lot of little things you need to consider in addition to just max wedge motor. Examples wiring harnesses, shiftr cables, acceleraor cable. Brake lines, trans dipstck tube if you are running an automatic. Complete max wedge exhaust system, headers or max wedge exhaust manifolds. If you narrow things down we'll be able to help out better.
