steve maluk
hello all
i can't get my light bar light to work nor my blinkers to work
what i have
got headlights /floor dimmer switch works high and low beam
all running lights work
taillights work brake lights work glovebox light works map light works overhead curtesy light works also goes out when doors are closed
motor in car but nor fired up yet
motor cranks but i don't have fuel to carb yet i would like to get all lights working first / steering column flashers work and both dash left and right bulbs work but no blinkers
i removed light bar and dimmer switch and bench tested dimmer switch light bar dims and gets brighter with dimmer
would a faulty headlight switch be a problem? when i flip the switch for running lights they come on then one more time up and headlights work headlight switch seems to work
i attached more ground straps to firewall
is there something that power needs to go through to get all this to work / a lot works but light bar
thanks, if someone can give guidance
what i have
