No spark
green 66
5:05 PM
Thomasville Nc
Just got dizzy rebuilt with new pick-up oil bushings etc,no I have no spark at the coil! Have juice at voltage reg and ballast resister but nothing to the coil. Msd 6a 6201. Car ran ok before I pulled out the distributor.Any ideas?
Check the air gap, should be between 13 and 20 thousands. Do not use a steel gauge, use a brass one.
I "think" .006 is right.
Believe box went bad-no spark to coil or distributor-maybe crossed wires?
Yep-that did the trick.Must have put it in limp mode or something.Works good now just have to fine tune it.Thanks for all the help!
