Now Here's One
ir3333
10:51 AM
ontario
A 65 Satellite is basically the same as a 64 Fury from the doors back.Can a 65 Satellite with a damaged front end be converted to a '64 Fury / Belvedere?
What all is required for this?
Yup, swap the front clip. Trim holes will probably be at the wrong height though. Even 64 Fury/Belvedere holes are 1/4" different.
Doug
It might be easier to put the front clip from thr64 on the 65. Cit or drill out the spot welds located under the rear seat, at the factory joints in the door jambs and hallway up the a pillar. This takes good measurements and patience.
O.K. tx guys
...obviously more than fenders,hood,grill and bumper and brackets
Depends if you want a "real 64". The front clip will fit, bolts on. Then you could leave the 65 rear. Or as mentioned the tail panel, trunk opening, and tail panel would require welding. I do not understand post #4 unless he's talking about a 4 to 2 door conversion.
Doug
