Coelacanth
- 6:04 AM
- May 10, 2024
- Edmonton, Alberta, Canada
While I was installing new fender splash shields on my '70 Charger, I noticed light shining through to the engine bay from inside the fender where there is a seam between the panels. The car originally had a large bead of black (or painted black) sealant of some sort, that is now decomposing and practically crumbling apart. I dug out the old sealer or whatever it was, so I can clean up the inside mating edges and try to fix or improve this area. I will need to unscrew a few of the mounting bolts in the engine bay where it bolts to the fender, but what are some options for re-sealing this seam, to at least prevent it from rusting (it looks worse than it is, the steel is good on the mating surfaces, just grubby)? I'm hoping I can straighten out the inner edge.
Not sure what this area is called, I'm calling it the "fender crease"; the same area on the passenger side of the engine bay has the same sealant bead, but at least it's straight and sealed properly:
