Papa Tom Sun Valley, NV
Papa Tom
New Member
9:01 PM
Sun Valleu, Nevada
Right now I am having an issue with the right rear tire moving forward to rub the forward part of the lower fender. it only does it in reverse. I just put 29.5 in. radial slicks on it and now I have this problem and I didn't have the problem with 28 in. tires on it. It seems the the axle is moving on the right side but not the driver side. Any ideas for a guy that has taken everything apart and put it back together and found nothing wrong. All bushings are like new.,
Welcome to FBBO from NorCal
maybe you could post the question/s in the
Brakes, suspension, rims tires forum section or
the General discussion or Racers Hangout forum sections
you will get more possible help that way
this is the welcome wagon, inteneded for intros, share a few photos
getting to know each other, share a story/history of you the car etc.
It's Not really intended as a Q&A Tech section,
there's nowhere near as many viewers here either...
my 1st guess would be something is either possibly lose/worn {?},
allowing the rear axle to wrap/twist possibly {?}
or move towards the front when in reverse gear
or the bushings aren't as good as you think...
Maybe the tires/wheels aren't centered in the wheel opening either...
Possibly a different front spring hanger may help...
good luck
