parting out 67coronet 4 door
65NUTCASE
11:48 AM
p.a.
Good running low mileage 318 Eddy performer intake and carb. All drum brakes. a/t. Good suspension. in P.A. 16637 everything cheap.. Pat
What wiper motor is in the car. Also interested in the driver side inspection cover on inner fender w/screws and upper horn.
thanks Dave
need trunk spare tirewell /wiring harness/underdash wiring
pat joe from jackson nj 08527 want to know if you removed the parts that i was interested in have a good easter mopar joe
I am looking for a r/h foward brake line. The hard line that goes from the proportioning valve, across the firewall, to the wheel well. It must have an approximately 4 inch rise in it where it crosses over the transmission tunnel area. Then it drops back down again before it drops to the wheel well area. I'd also need a set of 14 inch rear brake backing plates with the emergency brake cables and housings. And a small block engine wiring harness. Any help would be greatly appreciated
I'd be interested in the fender tag, certicard, or broadcast sheets if you find them.
How about the lower left 1/4 from the wheel opening to the bumper?
