Patriot headers
tileman61
8:55 AM
ashland ma.
Looking for headers for my 68 gtx wondering if anyone has patriot headers . And how do they fit .
I put the Patriots on my 69 Roadrunner, and the fit was great! Had to do a slight amount of dimpling where the tie rod hit the header, but that was the only issue. Been on there for 3 years now and no issues. Be sure to use teflon tape on the header bolts if you are using iron heads.
Just put a set on my 69 charger (400 block) Fit like a glove, OJ's glove! Tight fit getting in. Wouldn't install with engine had to come through the bottom after engine was in. No dimpling, close in some areas. The best thing was the angles were correct and the bolt holes lined right up with 440 Source CNC stealth heads.
Good luck
