good question is it power disc/drum or manual?Was it disc/drum or all drum?
Actually, I don't know if that even matters?
That booster is for drum/drum usage. For front disc you need the dual diaphram booster. I know first hand as I had that booster on my 68 Charger when I converted to front disc's. Not enough boost to hold the car. I thought it wouldn't matter but when I found out I could hold the brake and tromp on the gas, the car would walk away. I thought my master cylinder was the culprit but after speaking with Cass at Dr. Differential, I was enlightened. I now have the dual ballast booster. World of difference.
So in your opinion, having a booster on all drums isn't worth me retrofitting one on my car? I have all drums, manual right now.That booster is for drum/drum usage. For front disc you need the dual diaphram booster. I know first hand as I had that booster on my 68 Charger when I converted to front disc's. Not enough boost to hold the car. I thought it wouldn't matter but when I found out I could hold the brake and tromp on the gas, the car would walk away. I thought my master cylinder was the culprit but after speaking with Cass at Dr. Differential, I was enlightened. I now have the dual ballast booster. World of difference.
ok, i will pass then i need power disc booster.thanksGlad you pointed that out, I did not know much about the booster when I removed them. I had converted back to manual brakes.
