rustytoolss
Manual brake pedal ratio is 6 to 1. Power brake pedal ratio is 4 to 1 , But the power brake linkage goes through a bell crank assy and thing change. So does the 4 to 1 ratio change ? if so what does it become ?????
I was just trying to find out if the ratio changes, to figure out master cylinder bore size/pressure if I stay with the power brakes.The bellcrank changes the ratio, but my best guess is that it is 4 to 1 after the bellcrank. I don't have one to look at right now. It needs to be removed for manual brakes. You need a manual brake pushrod, and the firewall reinforcement plate probably needs to be changed also.
