WTB power disc brake caliper bolts
2:19 PM
johnstown,pa.
wanted : 4 power disc brake caliper bolts, part #6026751 will fit 66-69 b-bodys dodge & Plymouth. Need for 69 GTX , this part is not being reproduced,thanks for the previous replys .
Is this what you need? Have 2 boxes with 2 in each box........
Are they the bolts that attach to the spindles, and perhaps from the Bendix system? I have exactly what you need. Let me know if you want more pics/details.
no these are not the bolts I need. the bolts I need are 4 inches long ,they hold the caliper together on the head of the bolt is a threaded hole for the p/d/b/ hose bracket.
they are from the bendix system, but are not bolted to the spindles. thanks
Okay, so which ones are you looking for? I still have all the bolts from my front brakes. Are they the bolts for:
Dust shield?
Lower spindle bolts (connect spindle to control arm)?
I am actually selling the calipers themselves, so if you are looking for the bolts that hold them together, I'm sorry but they are included with the calipers. If it's any of the other bolts listed above, I'd be happy to help.
FYI
The op is looking for the two end bolts the hold the caliper halves together.
They are a unique, special, designed, and machined, head on those end bolts.
So he's looking for 4 of them, for both his left, and right si
de calipers.
Ah, I see. I wish I could help but I just sold my calipers to someone else! Sorry about that, but I wish you the best of luck in finding those bolts.
The new A1-Cardone calipers don't have the correct bolts on them either. I bought a set of them. I believe they used metric bolts to hold caliper halves together. I don't think you can swap original bolts to the new calipers, so you can mount the hose bracket. You would have to weld nuts to the top of the four caliper bolts to be able to mount the hose bracket.
That's the best option for the op to do with those 4 end bolts on the calipers.
Weld nuts onto the heads of some grade 8 bolts, if originals can't be located.
Originals have now gotta be dinosaur eggs, unobtanium, hens teeth, obsolete.
You are absolutely correct, thank you for clearing up my description of the bolts. I will keep on looking. thanks again.
