power steering gear box for 62 Fury B body
rustytoolss
6:47 AM
New Franklin, Ohio
What year(s) of PS gear box will fit in my 1962 Plymouth Fury ( B) body ? I was thinking that (1962-1972 A and B body , but not sure about that.) I have the small spline pitman arm.
You can also use the 5th Ave. or Dippy power steering boxes. The best is the Dippy police car box. These have a larger Pitman shaft, but you can still use them with a late '70's Cordoba Pitman arm. I have this on my 1967 Coronet R/T.
Early power steering pumps had larger 5/8" fluid return lines, so this is something to watch.
Thanks for the input. Did not know about the 5/8" return hose. Thanks
Is there a way to work around the 5/8" return hose ? I am able to but a PS pump from a 1963 Dodge 318 Polly ( which is the same engine tht I have)
That should have the same larger return hose.
The return nipple piece is easily interchangeable. If going to newer style.
