I swapped from from a federal to a Saginaw pump and now my return line connections are different. I'm needing the smaller fitting on the left. I currently have the one on the right. Thanks Stew
Firm Feel has a 'steering component boneyard'. With a simple phone call I got a 'newer' pressure fitting from them to get better header clearance. Of course that meant changing the hose, and having a different end swedged on so it would all work.
Hotrodders' Law: For every modification there will be two, or more, other modifications to make the 1st modification work.
