Power Steering Swap Question
HYRDGOON
8:24 AM
Breslau, Ontario, Canada
Can the power steering be swapped from a 67 383 Belvedere to a 68 Roadrunner? Should everything be the same (steering column I'm guessing might be the issue?) or should it be a direct swap?
The steering box is the same. If you swap everything over off the same car, it should fit without issues, as that steering box was used for quite a while. Swap the box, Pitman arm, hoses, pump, bracket and lines from the '67 to the '68. You might have to use the idler arm off the '67, as well, to keep the geometry right.
