Power Window Harness Companys?
dodge68charger
10:36 AM
Washington
Looking At Mine For My 69 Satellite, Its Seen Better Days..
Any Company Build a Stock Power Window Harness?
Jim Slotts AKA JS Restorations has been known to refurbish them.... There are so few P/W B bodies I doubt anyone would step up & reproduce the harness...
Personally I would clean up & repair what you have then add relays which means the main harness no longer carries the load, the harness & switches only carry about .3 amps to trigger the relays... The motors get full clean power... The windows work better than they did when the vehicle was new...
Member Crackedback makes and sells plugs n play relay kits.... Fact is he too might be a good source for restoring your harness..
Thank You. I Would Love To Make My Own Relay Harness If I Had a Template To Work Off Of.
I Will See If I Can Get In Contact With Them Today. Thank You
A template is easy, but you had better be very good at making high quality crimps... There are about 90 crimps & a bad one means you probably have gone backwards.... You need the right crimping tools, the right crimp terminals.... Honestly I just completed another one last weekend & if I were to do it again I'd probably buy the pre-made harness from Rob AKA Crackedback...
